Manual pedals with auto?
I am bout ready to do my e4 to zf swap and want to progress into it while I'm still gathering a few parts..
Will the zf5 pedals work with the auto transmission until I replace it?
I don't see why not as the clutch will just not have a function
Reason I want to do this early is because I've been told it's one of the hardest and tedious things to do during the swap (swapping pedals) and if I can get it done even before I get the new tranny in I'll be happy and feel ahead of the game.
You might think I'm crazy but I guess it doesn't hurt to ask lol
Thanks all again for the help!
not speaking from having done it myself .. i would have to agree , cant see any reason why they wouldn't work just fine ..
the master still gets a pedal and pushrod and the motor still gets a throttle cable so i think it should be alright .. good idea to space it out and have more beer drinking time when the time comes for the big kahuna
Received 3,186 Likes
on
the trans does not care what pedal assembly is in the truck.
the old parts runner at the body shop had an auto trans with manual pedal assembly in it for 13 years.
clutch down on the floor to start. if you wanted to use cruise control toe the clutch pedal all the way up.
Thanks for the quick replies fellas
on
You will have interference with the pedal assembly and the big aluminum support under the dash (if equipped, I think that started in 87 though). It's easy to clearance for the space needed.
I had an 84 F250 I went the opposite way with, replaced a completely worn out NP435 with a fresh C6, but left the pedal assembly. I also made a floor shifter out of the old 4speed one, it was good for messing with people.
Just did this put the pedals in a couple of days before swapping the tranny in. No issues. I had no clearance issues. I loosened the dash mount and parking brake mount. Just lowered the steering column took the 4 nuts holding the pedal bracket to the fire wall. Pulled brake booster forward maybe an inch. Took the bolts out hold the bracket to the dash. Pulled the bottom of the dash forward. Then barrel rolled it out to the left. Put the standard pedals in just the reversed process. No big deal.
I did this exact swap....works fine...I also tossed in hydroboost brake booster and MC while I was swapping pedalz...then months later swapped in the zf and c6 out.
Stupid simple but u will remove the entire steering column on a 91 fyi...so be prepared.
Remove dazhinstrument bezel trims
Remove instrument cluster ...speedo cable is hoo ha to do carful of PRNDL cable for indicator!
Remove steering column cometely from truck.
Unclip brake pushrod
Remove 4 bolts holding booster
Remove 11 mm bolt iirc holding pedal assembly up to dash...
Remove pedal assembly
InstLlation is reverse...
Bobs yer uncle
JM7.3CW Eh!
Bobs yer uncle
JM7.3CW Eh!
Bobs yer uncle
JM7.3CW Eh!
Bobs yer uncle
JM7.3CW Eh!
derrickmauk1003
03-26-2015 06:41 PM
390
03-13-2008 07:26 PM
oldcoupe42
01-27-2005 08:13 AM
