need help asap!!!!!
When you say "retaining clips" do you mean the stainless steel pieces that come in the box of new pads? I've bought pads that either didn't fit or if you were able to jam them into place, they wouldn't slide on the clips to release when you take your foot off the brake pedal. I think pads that are tight in their clips cause uneven rotor wear. First I clean the caliper areas where the clips attach and then I take the grinder to the ends of the pads to make them a little sloppy in the caliper bracket. I then spread a very light layer of high temp grease on the ends where I ground. Makes for even rotor wear.
I've done brakes where I had to knock the old pads out of the caliper bracket with a hammer...they gotta be making extra heat and causing uneven wear.
after taking a break in the house for a few mins I found my mistake. yes the stainless steel clips I had somehow put them in a different way thankfully I had not taken apart the other side yet so I was able to use it a reference and go from there.
thanks for the input
I guess from being in a hurry and working in the sun with a heat index of 110 I was rushing to finish and did not pay attention to what I was doing.
FordPickMeUp
05-01-2004 12:36 AM
