truck barely runs
Jarrett yes i have fuel , i did put some on the way home. It ran fine . No i not been able to check out the fuel filter. I have only had this truck about a month or so. I don't think that it has a chip .but then again I haven't looked. I am at work now i will be able to look at everything better when I get home tonight.
This should help..
Acronyms - Ford-Diesel Abbreviations, There are more but this is all I have.
2WD = Two Wheel Drive
4WD =4 Wheel Drive
4x2 = 2wd on a 4wd chassis (convertible)
4x4 =4 Wheel Drive
4r100 =Automatic Transmission for Super Duty Trucks with a 7.3
ABS =Anti-Lock Braking System
A/C =Air Conditioning
AC =Alternating Current
AIC =Auxiliary Idle Control
AIH =Air Intake Heater (SD 7.3)
APCM =Auxiliary Power train Control Module
ATF =Automatic Transmission Fluid
BARO =Barometric Pressure Sensor
BB =Bulletin Board
BBS =Bulletin Board System
BCA =2nd Best Bearing Company
BFH = Big Freaking Hammer
BTW =By The Way
CAI =Cold Air Intake
CC =Crew Cab (4 door)
CCV =Crank Case Vent
CDR =Crankcase Depression Regulator
Cork = Muffler
CPS =Cam Positioning Sensor
DC =Direct Current
DORA =Dealer Order Receipt Acknowledgment
DI =Direct Injection
DIY =Do It Yourself
DRW =Dual Rear Wheels
DTC =Diagnostic Trouble Code
DVOM =Digital Volt-Ohm Meter
E4OD =Auto Transmission OBS
EATC =Electronic Automatic Temperature Control (climate control)
EBPV =Exhaust Back Pressure Valve
ECM =Engine Control Module (not in Powerstrokes)
ECU =Engine Control Unit (not in Powerstrokes)
EEC =Electronic Engine Control
EGR =Exhaust Gas Recirculation (not on 7.3)
EGT =Exhaust Gas Temperature
EOT =Engine Oil Temperature
FASS =Fuel Air Separation System (not for OBS 7.3, shouldn’t be on any 7.3)
FAQs =Frequently Asked Questions
FICM =Fuel Injection Control Module (not on 7.3)
FPR =Fuel Pressure Regulator
FTW =For The Win
FWIW =For What It’s Worth
GM =General Motors
GP =Glow Plug
GPR =Glow Plug Relay
GVWR =Gross Vehicle Weight Rating
HFCM =Horizontal Fuel Conditioning Module (not on 7.3)
HEUI =Hydraulic Actuated Electronic Controlled Unit Injector
HPOP =High Pressure Oil Pump
IAT =Intake Air Temperature Sensor
ICP =Ignition Control Pressure
IDI =In-Direct Injection
IDK =I Don’t Know
IDM =Injector Drive Module
IIRC =If I Recall Correctly
IPR =Ignition Pressure Regulator
Kitty = Catalytic Converter
LMAO =Laugh My **** Off
IMHO =In My Humble Opinion
IMO =In My Opinion
JD =John Deere
LB =Long Bed
LOL =Laugh Out Loud
MAF =Mass Air Flow Sensor
MAP =Manifold Absolute Pressure Sensor
OBS =Old Body Style
OD =Over Drive
OEM =Original Equipment Manufacturer
OMG =Oh My Gosh*
OP =Original Poster
OTC =Owatonna Tool and Equipment Company
PATS =Passive Anti-Theft System (ignition keys w/chips)
PCM =Power train Control Module
PCV =Positive Crankcase Ventilation
PDL =Power Door Locks
P/M =Power Mirrors
PM = Private Message
PO =Previous Owner
PS =Power Steering
PSD =Power Stroke Diesel
PT =Pigtails
PTO =Power Take Off (winch)
PTTTM =Power Telescoping Trailer Tow Mirrors
PW =Power Windows
PWM =Pulse Width Modulation
PWM =Power Window Motor
RC =Regular Cab
RKE =Remote Keyless Entry
ROFL =Rolling On The Floor Laughing
RSK =Reverse Shackle Kit (moving the front axle’s forward shackle to the rear of the leaf)
RWD =Rear Wheel Drive
SAS =Solid Axle Swap
SB =Short Bed
SC =Super Cab (extended cab)
SD =Super Duty
SRW =Single Rear Wheel
TC =Torque Converter or Transfer Case
TIB =Twin I-Beam (4x2 front suspension)
TPS =Throttle Position Sensor
TSB =Technical Service Bulletin
TTB =Twin Traction Beam (OBS only, D44 in Bronco/F150, D50 in F250, 4x4)
TTM =Turbo Temp Monitor
UVCH =Under Valve Cover Harness
VAC =Volts Alternating Current
VDC =Volts Direct Current
VECI =Vehicle Emissions Control Information
W/E =What Ever
WMS =Wheel Mounting Surface
WOT =Wide Open Throttle
4WD =4 Wheel Drive
4x4 =4 Wheel Drive
BB =Bulletin Board
BTW =By The Way
Cork = Muffler
DC =Direct Current
DIY =Do It Yourself
FTW =For The Win
GM =General Motors
GP =Glow Plug
IDK =I Don’t Know
IMO =In My Opinion
JD =John Deere
LB =Long Bed
LOL =Laugh Out Loud
OBS =Old Body Style
OD =Over Drive
OMG =Oh My Gosh*
OP =Original Poster
P/M =Power Mirrors
PO =Previous Owner
PS =Power Steering
PT =Pigtails
PW =Power Windows
RC =Regular Cab
SB =Short Bed
SD =Super Duty
W/E =What Ever
When my fuel pump went out it started running very rough. Eventually within a mile of the first symptom truck gradually slowed to a stop an quit. I once had a OBS that had the pump go bad. It ran rough but never quit; I drove it very slowly home from about 5 miles away. So I'm thinking these pumps can go bad but sometimes the engine will run enough to get you somewhere and sometimes they just stop running.
After i replaceed the fuel filter and filled the resivior . I cranked it over got it to run same symptoms and as I was looking around i noticed that the electric selonoid was smoking and very hot . Now what should i look at and what does that selonoid control?
