What's a good egr delete to get
Do you have a set of torches? The passenger side is tight. If you have an aftermarket exhaust with a 2 piece down pipe it is easier.
If it is a stock one just blow the bolts with a torch.
You will have everything apart so it should be easy.
If you get the kit I linked keep in mind to put the pipes in before you do the final assembly. I would recommend that you put the pedestal and turbo in and install the up pipes. Then remove the turbo and put in the intake.
It would have gone easier for me if I would have done it when I did the HPOP.
I hate to debunk common perception on this issue,, but first off, I have a video somewhere that shows me dragging an engine around by the up pipe that is bolted to the manifold with no y pipe even on it. The bellows do not need the cooler to be stable. The force needed to remove the fasteners from the up pipe,, to the y pipe are generally what causes bellow issues. This is what we do
There's no comparison.
Here is a vid I found in my phone that shows some ipr up pipes.
Not to mention a couple more vids I have of the castings not being up to par. I used them for a long time. And I will not eat someone else's mistakes. Rant over. It's prob gonna be deleted. Lol.
