73 F350 Super Camper hitch
I have had good luck with Curt hitches from Etrailer. They have one listed for a 1973 F350. I would suggest measure the width of your frame rails and call and double check when you order.
The hitch will probably use holes already in the frame - Etrailer will probably know. If not drilling is not too bad if you have or can borrow a 1/2" drill... mark the hole center with a center punch and start with a nice sharp 1/4" bit for the pilot hole then 3/8" then 1/2".
PS: safety glasses are a really good idea if you drill as the chips will fall down towards you.
https://www.etrailer.com/hitch-1973_...250,+F-350.htm
GuitarJesus
06-10-2017 10:51 PM
LeeShuster
09-23-2010 09:50 PM
pacecar1979
12-09-2009 04:52 PM
SoTX yellow
05-19-2004 09:49 PM
Cfidave
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
05-18-2004 03:20 PM
