Hi guys this is my first diesel at first it was running but i would have to spray starting fluid every time i turned it on. Then one morning it just stoped now it just cranks i changed the fuel pump the cam sensor some people tell me its my HPOP and other tell me its my glow plugs. 95 f350 7.3 turbo diesel
please don't use starting fluid unless you enjoy fireballs
does the tach move when cranking?
Any smoke from tail pipe?
mine took a while to prime when I changed out my pump, can take 5 minutes cranking, just let the starter rest a bit between cranks or your starter will be gone
My 97 did that the other day, I never used starting fluid but I found out it was a blown 30 amp fuse. I went ahead and unplugged my fuel bowl heater and now she fired right up and doesn't stall on me anymore.
