Receiver size
#46
New ones represent 160 more horse power and bunches more torque. And you wouldn't want to see the rust now. Some handy new places to hang the trouble light when doing brakes.
#47
$300 and here is the best hitch I've ever had. Provides the tongue weight, 2.5" shank, 14k rating and adjusting the height is easy with the keyed lock pins, it's aluminum so it weighs 15lbs., when not towing just remove the ball mount and you're left with a clean drop bar.
I use brass shim stock to settle it in to remove any rattle. When I get a '17 or '18 truck I will likely make a sleeve and shim it so that its snug.
#48
#49
#51
Weigh Safe Hitches - 4in. Drop 2.5in. Shank Adjustable Ball Mount With Scale | 4WheelParts.com
#53
#54
I emailed manufacturer of the weigh safe and hope they reply regarding contamination of the ball socket from winter chemicals and grit/sand. Seems to me there should be a seal or o-ring around the pin to keep the socket clean. I also asked them if there was any protection against corrosion since those of us in the Northeast and rust belt are somewhat sensitive to expensive items which might be destroyed by the environment. Also asked about possibility of 3" hitch to alleviate the sleeve. Will post their response when it comes.
#55
Here is the response from Weigh Safe, posted with their positive permission:
Rob,
Thank you for your interest in our Weigh Safe products.
1. We are in the early stages of development on a 3" model. Hopefully we will have something by November.
2. Our products have held up extremely well under these harsh conditions.
3. There is .01 tolerance between the ball and socket. We have considered a seal, but have not found a good solution yet.
Brandon Doman
LEAP Innovations, LLC.
www.weigh-safe.com
Rob,
Brandon Doman
www.weigh-safe.com
#58
etrailer.com has always been abreast of new developments and I have enjoyed working with them over 15 years. There may at times be a little better price but they consistently have the right answers and videos so I feel a dedication to them.
At this time there is very little on the 3" frontier. I watched the Ford video showing the sleeves and the first sleeve (3" to 2 1/2") has a rim which seats against the receiver. That should make it much easier to use than a straight sleeve which never wants to line up correctly. Titan class 2 1/2 inch ball mounts are readily available now and I will probably stick with them as I have several for different trailers. I probably will, however, build a new 3" x 30" extension which will hold a 2 1/2" ball mount for pulling boats while the camper is on board. I welcome the stronger receivers for just that use.
#59
E trailer... Currently Reese is the only one who makes a 3" ball mountReese - Class V: 3" Ball Mounts. they also make a pintle mount and hooks in all 3 ball sizes. http://http://www.reeseprod.com/prod...UT5nHOu12WXOZK And the 1/4" pin thing ford has a reducer sleeve for that too
#60
