Drone from my 6.0
Drone from my 6.0
Hi all, just got in after a 2 hour trip in my 6.0.
Either it was me going crazy or I started to notice a hum or a drone coming from the front that wasn't the usual clatter of the diesel engine. Think Civic with a fart can except 5 miles away. It was that sound coming from the engine. As revs were higher the sound would be more pronounced. If I was cruising then took my foot off the pedal the drone would go away.
Sometimes I get turbo lag. Also some oil has been leaking out of the pan because I didn't tighten the screw far enough (everyone says to not tighten it too much....) so I've put some more back in. Other than an oil change that I did about a week ago I do not know last when fluids were changed, I just recently came into ownership of this truck. I have no prior experience with turbo diesels.
Could there be a problem with my turbo system? Exhaust system?
Thanks!
Thanks!
Aftermarket exhaust? Check the exhaust down pipe from the turbo, it has a bad habit of touching a cross member or the firewall and vibrating. Stock exhaust, could be a band clamp that's loose causing a vibration.
If your oil plug isn't sealing well, there's a copper washer you can replace. P/n 3C3Z-6734-AA. Or get a Fumoto valve, mine was installed once and hasn't leaked a drop in 60k miles:
https://www.amazon.com/Fumoto-F-111N.../dp/B003VCBDG4
There does seem to be a fiber board type liner on the firewall that's coming loose. Maybe it's vibrating against the pipes? I'll check for other vibrations but that could (hopefully) just be it.
Turbo lag seems to be a random problem, not reoccurring. Hopefully there's nothing wrong with my turbo system. However, there is a high chance since my truck is essentially a DD mall crawler.
That Fumoto plug looks interesting, I guess the exposed threads go into the pan and then there is a system inside that allows fuel to flow through when the lever is turned?
Thanks for the information so far!
BIG-DOG-DADDY
10-14-2008 01:52 PM
