1996 7.3 injectors? Hpop? Idm?
Old 07-03-2016, 07:18 PM
1996_powerstroke's Avatar
1996_powerstroke
1996_powerstroke is offline
I've been dealing with this problem for a month now and about had enough of it. The truck won't rev past 2000 rpms in neutral. When I drive the truck cold it'll run fine sometimes. When it gets warm the truck won't go past 2000 rpm in all the gears. I checked the fuel filter it was black. Pulled the orings and one was missing an oring. Changed the orings. Changed the ipr valve. Noticed the uvch were melted and changed them. Nothing changed the problem. I pulled the idm off of my brothers 95 7.3 and only the driver side cylinder works. But while his is hooked up the truck revs past 2500 rpms. I hooked mine back up and all cylinders work but don't rev past 2000 rpms. Is it injectors, hpop, or idm?
Old 07-03-2016, 07:24 PM
z31freakify's Avatar
z31freakify
z31freakify is offline
Received 1,192 Likes on 818 Posts
Tell him to lend you his PCM just to verify its not the pcm.
Old 07-03-2016, 07:27 PM
oldbird1965's Avatar
oldbird1965
oldbird1965 is offline
How many miles on the injectors?
Old 07-03-2016, 07:30 PM
1996_powerstroke
253000 miles. I changed the orings 2000 miles ago and again now
Old 07-03-2016, 07:32 PM
z31freakify
What brand of O rings are you using? Are you torqueing the injector bolts to spec?
Old 07-03-2016, 07:42 PM
1996_powerstroke
The first ones were motorcraft and the second ones were victor reinz
1996_powerstroke
The first were motorcraft and the seconds were victor reinz.
Old 07-03-2016, 07:56 PM
z31freakify
Always use Alliant or Motorcraft (also supplied by Alliant) these are only ones that will last. Make sure the O rings are lubbed good if not they are going to get torn while installing, also make sure they are torque good I'm going to say 25ft/lbs. Not 100% on that.
Old 07-03-2016, 08:39 PM
97-psd's Avatar
97-psd
97-psd is offline
swap his pcm with yours
Did you get a check engine light with his IDM installed?
did you try your IDM in his truck?
Old 07-03-2016, 08:43 PM
1996_powerstroke
The check engine light comes on when it's running with his hooked up. I can't try mine on his because his is down to the frame.
Old 07-03-2016, 10:14 PM
97-psd's Avatar
97-psd
97-psd is offline
well, that certainly limits you some. Can you pull the codes once you set the check light? at least now you know it will rev above 2000. Once you swap the pcm, use it with your idm and his and see how it performs, hopefully that will narrow it down to the root of the problem
Old 07-03-2016, 10:33 PM
1996_powerstroke
It don't throw any codes
Old 07-04-2016, 09:47 AM
1996_powerstroke
With his Pcm hooked up to my idm its runs the same. With his Pcm hooked up to his idm it lopes even worse
Old 07-04-2016, 02:00 PM
fordpride's Avatar
fordpride
fordpride is offline
You said above the CEL comes on. If it's on it has a code
RenoHuskerDu
33
10-25-2017 08:31 PM
1996_powerstroke
06-20-2016 05:04 AM
szotty
Ford Truck Parts for Sale
11-04-2015 02:15 PM
goatz
13
08-13-2009 10:06 AM
catbird7
10-03-2008 07:56 PM
Quick Reply: 1996 7.3 injectors? Hpop? Idm?
