95 e350 air conditioning issue
My 95 7.3 E350 air conditioning has issues, front air will work and blow cold then suddenly stop blowing cold and will blow hot - in awhile it might start blowing cold again, it just depends, no rhyme or reason that I have been able to see. Will work good then stopping going into the store and restarting and it will blow hot until it feels like blowing cold again, then at times it will go for extended periods without an issue.
Moving the function selector and temp control makes no difference.
Now, the whole time this is going on wit the front the rear air is working good and will always blow cold air.
Any help would be appreciatted.
Thanks in advance.
s.r.
Thanks in advance.
s.r.
Thanks in advance.
s.r.
Thanks in advance.
s.r.
It could also be an expansion valve on the evaporator, the rear unit evaporator has its own valve so it would work normally.
The only other thing would be a blend door that has come loose in the plenum. Can you detect any door moving when operating the temp control? The blend door sets the amount of from the evaporator and heater to adjust temperature. jim
https://www.ford-trucks.com/forums/1...a-c-issue.html
If you can, the next time it switches, feel the tubes going into the evaporator, one will be scalding, flesh melting hot (don't touch that one), the other will probably be sweating and cool or cold.
If it blows cold air in back I would forget the A/C troubleshooting for now.
I do not know if your system uses electric or vacuum to operate the blend door. Here is a document on the electric system. You will have to determine which system you have. jim
https://dl.dropboxusercontent.com/u/...20ACTUATOR.PDF
In post 5 & 6 it was asked and you replied to a statement about the tunes going into the evaporator. The statement you amde was it turns hot. Meaning the AC system is not functioning correctly during the times of no cold air.
While some of the above items can and do cause that condition, if the evaporator isn't getting cold intermittantly that is a problem. Either because the system is low on referigerant or there is a restriction in the system usually from debris.
>>>>>>>>Action
>>>>>>>>Action
I think it is electric, the temp control goes into box behind dash that is only wired in, that makes more sense than anything. will look at see if I can find the parts in the van. wish there were pictures. As fast as the temperature change is it is like the cold is shut off instantly and then started back the same way. Door or actuator most likely.
>>>>>>>>Action
>>>>>>>>Action
"Now, the whole time this is going on wit the front the rear air is working good and will always blow cold air."
That says A/C is fine. Even if the front evaporator were bad (failed expansion valve), it would not blow HOT. The heater and A/C both run all the time except on FLOOR on some models. The temperature control blends the 2 temps to get the desired temperature. If the controller for the blend door fails intermittently, the temp can change from full A/C to full HEAT instantly. Blend door and blend door actuators are common failures.jim
