Injector Cushion Ring
While working on an HPOP leak today I found at least 2 injectors missing the metal bushing that goes between the snap ring and o-ring in the top of the injector. Best thing I could find to describe what I was looking for was cushion ring. In the photo attached via link It is the asterisk. Anyone know where I can find these?
https://drive.google.com/file/d/0B5tjP7vTYX6bVmdWbmFYbnA3WTA/view?usp=drivesdk
Alliance sales them..... You will have to buy an injector Oring set... It comes with both the oring and the clip. Question is why did the come off? If your hpo rail nipple cup orings are bad then u should see oring damage in the top of the injector. Alliance also sales the orings for the hpo oil rail. Hope this helps..... I have a part number up in my shop if u need it..... Just did mine
