Pertronix I or II for '66 352?
From other posts, Pertronix seems like a decent choice to upgrade from points to solid-state ignition.
=> But for '66 352, is there a noticeable benefit for Pertronix II vs Pertronix I?
=> Also, can anyone confirm if model 1281 works in 352? One site says "fits most Ford V8s 1957-1974". Another says 1281 doesn't fit 1966 F100 352.
Thanks,
Bill
Thanks,
Bill
http://www.ford-trucks.com/forums/1441181-pertronix-i-or-ii-for-66-352-a.html
Thanks,
Bill
Thanks,
Bill
I went with the Pertronix III and matching flamethrower coil on my 66 352. I wanted the thermal protection feature and was curious about the multi-spark. I can only compare it to points, which were new at the time, but there was a noticeable difference in how the truck ran. I also kept the resistor wire in place and used it as a switched input to a relay that provided a full 12v to the coil.
Regards,
Corey
Regards,
Corey
If you read the instructions, you will see that all Ignitor modules, I, II and III require 12 volts. In the case of the Ignitor I, the resistor can remain in place but it is bypassed for the module.
Coils can be just about anything as long as they meet the minimum specs outlined in the instructions.
Instructions:
http://www.pertronix.com/docs/instru...heets/1281.pdf
http://www.pertronix.com/docs/instru...eets/91281.pdf
http://www.pertronix.com/docs/instru...eets/71281.pdf
Instructions:
Those are the newer instructions. Since I got the I when they first came out in the 90's I still have the instructions. No mention of needing 12V in it and so neither my Cougar or Mustang have 12V to them. Both have run fine for the last 20 years on the original I. My Park Lane, F100 and Polara have the II and do run 12V with the appropriate Pertronix coil.
Trail Master
07-06-2004 01:25 AM
