Just had tranny rebuilt. Now sometimes at red light or stop sign it Boggs down. Had it back already to shop that did the rebuild, he said it needs a tune up. Did tune up, still bogging down. Anyone with any ideas of what it could be with the tranny?
That can happen if the torque converter clutch is drifting on. That can happen from low trans fluid, low pump pressure, leaking internal seals, sticky torque converter clutch control valve, or a bad torque converter.
Thanks mark. Dropped it off 2 hours ago and he said he had to check a couple of those things you mentioned.
