Horn contact and spring
on
I always get a few extra ones at the PnP JY when someone has already removed the steering wheel and it's just sitting their or laying on the floor of the vehicle.
It never hurts to have a few of those small back up parts that are not easy to buy off the shelf that loco parts stores don't carry..
Orich
Orich
C2OZ-13A821-A .. Horn Brush / Reproduced by Carpenter.
1961/72 F100/250 2WD / 1966/72 F100 4WD / 1967/72 F250 4WD & F350 // Misc. 1960/66 Passenger Cars.
Note: Carpenter does not supply the horn brush insulator that this Ford part number (as a kit) includes with the brush.
If you need both, let me know, dozens are available NOS
Just this morning I was fixing my (intermittent) horn. I scuffed and cleaned all components and got it working reliably. However, when I scuffed the Dennis Carpenter brush over sandpaper, I lost about 1/8" of it. It's made of a very soft graphite-like material. The Ford brush withstood the sanding. I think making one might be a good idea, using copper rod instead of brass.
Eric
Eric
Hey, ND. Yeah , I don't have either part.
Your 1972 is different, doesn't have an insulator.
The brush is the same 1961/72, but it's located in a different place 1971/72 so doesn't use the insulator.
1961/70: The horn brush and insulator fit into a hole on the outside of the 3 spoke steering wheel, visible when the horn button or horn ring is removed.
1971/72's use a 2 spoke wheel with a horn pad. Here's a pic, the brush is shown as 13A824
LMC HAS THEM FOR $14. I didn't see one offered in NPD's catalog.
In the DC catalog, it calls for 2 of these?
For 1961-72 F100/250 application order C20Z-13A821-A
http://cdnll.dennis-carpenter.com/im...Z-13A821-A.jpg
I only have on slot.
I don't believe my column is the original though and I don't have the original steering wheel. It's an after market.
But does this look like the correct one?
Thank you ND. That's definitely what I need.
samntx
07-25-2022 09:43 PM
