Bigger Fuel Injectors For Camshaft Swap?!?
Agreed....polishing ports is a marketing gimmick. "I'll charge you an extra 10 hours to polish your heads" . It is quite possible to lose power on some head designs by polishing the intake and reducing atomization.
Polishing combustion chambers, without removing any material, is good though.
If you can afford it, ditch the stock heads altogether....if you want to mill for compression, keep in mind if you take a lot off (there is a lot to take off) make sure you align your intake and get it milled if necessary.
Yeah, I just really need someone to guide me through the rebuild process as far as what machine work and type of pistons I should use. I'm kinda looking for a low- mid power and high torque motor.
You can buy pistons that increase your compression, or mill the heads. You can run much more than 9.5:1 if you plan on using 93 octane anyway. I'm around 10.5:1 with cast iron heads. Milling e7s for substantial increase in compression is going to take a lot of material, relatively speaking....something like .050+.
Does shaving, or decking the heads effect quench in any way? If it don't my plans are to have an almost zero decked block, leaving the Sealed Power Cast Aluminum Flat Top Pistons with 4 Valve Reliefs about 0.005 in the hole. Then using a Felpro Head Gasket with a thickness of 0.039 to 0.041 compressed. This should give me a decent quench area, but as long as if decking my heads 0.008 to 0.012 doesn't effect anything. Also will I still achieve decent piston to valve clearance?
Milling won't change quench height, only real factor there is head gasket and piston protrusion past the deck.
Milling can change quench though, but normally by milling and changing the overall area of the combustion chamber to a more "focused" point doesn't effect quench negatively.
.045 is just fine for a low rpm steel rod application. The problem is, just have to be damn sure you have all of your measurements and specs are correct.
It is never a bad idea to physically check p2v clearance and quench, small amount of time compared to how long you expect your engine to run.
When swapping from the roller lifter cam to the flat tappet do you need to change push rods as well? Longer? I'm planning on using the Comp 35-255-5. Thank you!
on
If you were going from flat tappet to roller or vise versa then yes different pushrods are necessary(shorter for roller cam), but you aren't since your motor has a flat tappet cam in it now and the Comp 35-255-5 is also a flat tappet cam.
#28
on
Yes.. that motor went to a roller cam in 1994, and if you are rebuilding it don't go backwords to a flat tappet cam use a roller cam instead. If the original cam is worn out or damaged then replace it with the same or one of the aftermarket roller cams grinds that are similar... Comp 35-512-8.
covshark
24
02-13-2013 03:39 PM
