#22 fuse blows
#22 fuse blows
Hey I have a 1994 f250 7.3l powerstroke the #22 fuse blows everytime the key is turned I have already unplugged the fuel bowl heater and it worked for a month or so now it's happening again and it's blowing the fuse everytime does any one have an idea what it could be? is my pcm burned out and it cranks but I have no wait to start light anymore and help would be greatly appreciated I'm stuck in a bush camp
Your going to have to find the short. Fuse 22 powers the pcm as well. By the hpop reservoir there is a wiring clip that goes to the icp,ipr, fuel bowl heater, and water in fuel light IIRC. Unplug it and see if the fuse blows. You truck won't run with it like that but it will tell you if the wires running below the fuel bowl have rubbed through.
Sorry I wasn't clear enough. The harness you will be looking for goes from the bowl heater under the bowl and up the other side where it connects into the main harness. There should be a multiport connector either Close to the main harness or inside it. Sorry I don't have a pic and I modified my harness for efuel. Ie no more of that stuff
angel29
02-19-2012 04:00 PM
StillNotKing
02-20-2011 07:43 PM
