7.3-351m
06-15-2016, 03:14 PM
on
7.3-351m
I have a 1989 f250 4x4 with a 7.3lb I removed it and replaced it with a351m and np435 4sp manual Trans I'm havering trouble trying to figure out what mounts to use. Any body got a solution
06-15-2016, 03:30 PM
The cross member should have the holes there to mount the factory motor options from that era.
On a side note. What did you do with the 7.3?
06-15-2016, 04:16 PM
on
Quote:
Originally Posted by
pgg00
I still have it It split #2 piston in half
06-15-2016, 05:52 PM
since that body style never came with a 351M, you are most likely going to have to fabricate the mounts.
06-16-2016, 11:54 AM
The 351M came in the F-250 and F-350 in the early '80s ('80 - '83?). Would mounts from those trucks work?
06-16-2016, 12:05 PM
on
Howzit 351m
Do that make an adapter bracket for something like that and should I be looking for towers also?
06-16-2016, 08:21 PM
If you can find the ones that nothing special is talking about they should bolt up
econochris
07-25-2018 07:18 PM
Bgilmore480
1999 to 2016 Super Duty
10-09-2017 09:02 AM
Watcher58
09-27-2015 01:37 AM
shortstuffrm
11-25-2006 09:09 PM
