Rubber/Vinyl flooring for an '88? Does it exist?
I don't like carpet in trucks. The way I work them, it always gets nasty and stays that way. I'd much prefer the rubber/vinyl/work truck flooring, if I could find it. The only place I've seen such a product offered for my '88 was LMC, and I've heard/seen too many PITA stories to even consider it. Can it be found anywhere else?
Received 3,118 Likes
on
The carpet from an extended cab truck can be cut to go up the back wall of a single cab truck in place of the carpet that's usually on the back wall. Having a one piece of rubber running from the rear window all the way to the firewall helps keep junk behind the seat from getting lost and keeps whatever dirt that gets behind the seat from getting under the carpet.
Thanks for the link FordxFour, but I can't find my truck on there? It doesn't appear as though they have any options for a regular cab, 5 speed, manual 4x4 1987-1996 truck.
f100, I'll check out stockinteriors. Thanks. Edit: I recognize the stockinteriors.com website. I was just reading yesterday about a member who was having a problem with their product. I kind of got the impression that they were like LMC Truck in this regard? Or have you had a positive experience with them?
Edit Number 2: It would appear as though stockinteriors.com doesn't have an option for an '87-'96 regular cab, manual transmission, manual 4x4 either. What gives? Am I misunderstanding how they classify these products?
There are different types: 2WD with A/T; 4WD with A/T; with M/T.
Ford also offered accessory full width front vinyl floor mats in colors that were placed over the carpet.
All these mats are probably obsolete, but there may be some available NOS
on
So is it Worth Buying {$197+Shipping} for the Digital Cut Weather Tech Floor Matts will or won't fit ? Do you or Anybody have a Pic of a set in a vinyl floored Truck .............
