Wheel Bearings Question
Received 6,711 Likes
on
My new-to-me 2006 Gearbox 22FB toy hauler has the EZ Lube feature. My service guy just called to say the back bearings (I assume he means inner bearings) are dry. Based on the way he described the EZ Lube feature the outer bearing get lube but not the inner.
Does that sound right?
on
This is a debated issue.
I am in the camp that does not feel the advantages of using the EZ lube features outweigh the potential for pumping grease onto the brake shoes and drums as I have seen this frequently. Also, if you use EZ lube, do you ever break down your hubs and check the drums and shoes?
Others take the position that if you are careful and do it right, EZ is a real advance.
I break all my hubs down once a year in the late fall. For me, it is just part of my routine maintenance. I think everyone has to decide for themselves.
Steve
Steve
on
The service guy mentioned that it was possible to get the grease on the brakes. So I'll have to be careful.
I'm rather **** about brakes so I'm likely to open them up once a year just to check the brakes. I guess I'll check the bearings as long as I'm there. I need to learn how to do that on a trailer axle. I'm not familiar with electric brakes.
Once you get this down, it is pretty basic. I keep a set of rear seals and just pop out the old, grease the bearings and pop them back in along with a new seal. I focus a lot of attention on this issue because it is such a pain if you have a bearing go up in smoke on the Interstate.
Again this is just me. Lots of folks feel differently.
Steve
Steve
if E-Z Lube was smart.. they could add a pressure release valve ..to prevent blowing out the inner seal...
and YES, travel trailer or boat trailers.. over use or under use of E-Z lube is major cause of bearing failures....
and non E-Z Lube type products has even more bearing failures.
Drum Brakes are easy. been around for 100 years.. Trailer brakes just add a wired magnet. and it just needs inspection.
and most do not have self-adjusters.. so easier and less parts.
if you use a temperature gun.. for tires and hubs... if hubs start going up more the 25 degrees of normal .. you need to look at the bearings.
for my setup.. tires run 20 degrees above Air Temperature... and hubs run 30 degrees above Air temperature.
** BUT if you have used the trailer brakes hard in the past 10 minutes*** the hub temperature will be higher.
add/allow 10 degrees for the Side facing the Sun while driving.
my opinion.
my opinion.
I think one of the most valuable measures is hub to hub comparison of temperatures. Although there is no way to give hard numbers that fit everyone given multiple difference between campers that can affect temperatures, I find all my hubs run almost exactly the same temperature, that less than five degrees between them.
Steve
Steve
Irelands child
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
08-17-2015 02:32 PM
bmwcarl
03-23-2015 10:24 PM
