Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
1972 f600 rear wheel cylinders
Old 06-08-2016, 09:37 AM
jasmoore's Avatar
jasmoore
jasmoore is offline
I am replacing all rear wheel cylinders on this truck, it has two per side. My question is are the cylinders all the same. The same part #? It is 15x6 wagner brakes. thanks
Old 06-08-2016, 04:50 PM
85e150's Avatar
85e150
85e150 is online now
Received 1,596 Likes on 1,301 Posts
Welcome to FTE.
I'm doing a search on this and have found on older trucks, the cylinders are the same. Look at the illustration in post 3 to see if it matches what you have.
Do you have the drums off yet?
https://www.ford-trucks.com/forums/1...-cylinder.html
Post 4, says all 4 the same, not your year though.
https://www.ford-trucks.com/forums/1...nder-part.html
Others report finding these at NAPA, but you have to find a store with people old enough to know how to use a paper parts book. Good luck with it. You may get some other replies here as well.
Old 06-10-2016, 03:07 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
1972 F600 rear wheel cylinders.
4) C5TZ-2261-B .. Rear Wheel Cylinder - Use with Hydraulic Brakes - 1 5/8" diameter / Obsolete ~ 67 available NOS
1965/67 F600 with 15" x 5" & 15" x 6" brakes with 17,000 & 17,500 lbs. rear axle capacities / 1968/72 F600 with 15" x 5" brakes.
1968/72 F600 with 15" x 6" brakes with 17,000 & 17,500 lbs. rear axle capacities.
I didn't look for applications after 1972.
Old 06-10-2016, 05:36 PM
85e150's Avatar
85e150
No right or left side, all 4 the same, right?
Old 06-10-2016, 07:01 PM
NumberDummy
Correctamundo Sir, and congratulations on becoming a moderator.
4) C5TZ-2261-B =
15 x 6 with 18,500 lbs. capacity rear axle: F700; with 34,000 lbs. capacity rear axle: HT950; LNT800 and etc.
Millam
10-27-2018 12:36 AM
Pbbbfischer
07-18-2015 07:49 PM
alecs
10-02-2014 07:37 PM
projectdagger
02-18-2013 11:27 AM
OGB
11-04-2010 12:06 PM
Quick Reply: 1972 f600 rear wheel cylinders
