1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
O/D button working inverted????
Old 06-07-2016, 12:43 PM
Xcursion88's Avatar
Xcursion88
Xcursion88 is offline
I'm sure someone has had this situation...
Push the o/d button to turn off, light on shifter comes on as off...and the rpms drop.
Push the button again (turning O/D on) and the rpms increase. It appears its working 180 degrees opposite of proper.
Example to clarify...going down hill at speed, push the O/D off button and as before working correctly the rpms would increase allowing the engine to aid in some braking.
That is now 180 degrees opposite. Push that button while descending and the rpms drop like it got thrown into neutral.
Old 06-07-2016, 05:32 PM
Rongold's Avatar
Rongold
Rongold is offline
O/D REVERSED
It sounds like a computer glitch. I would disconnect the battery or batteries for a few minutes and then reconnect. See if that solves your problem.
Old 06-07-2016, 05:47 PM
clem1226's Avatar
clem1226
clem1226 is offline
Sounds like the torque converter is unlocking when it drops out of overdrive.
itsnotanova
30
09-14-2022 01:02 PM
KoolAidMan888
11-28-2010 09:08 PM
ryno311
1997-2006 Expedition & Navigator
05-06-2007 10:08 PM
CBSuperduty
08-18-2003 09:24 PM
Quick Reply: O/D button working inverted????
