pulled the trigger
Yeah the 95 needs it, I still need to replace tie rods, I just replaced the axle bushings a couple of weeks ago. Right side exhaust manifold gasket is leaking and the rubber cup inside the clutch reservoir has a split in it, that may be the reason the cutch is coming in about 1 1/2" off the floor.
The new F350 needs a little attention also, the guy I bought it from just put on new sway bar links and the passenger side one pulled the grommet right out, don't know why unless he installed it with too much tension on the bar. It might have something to do with the 20" wheels the thing is running too. I need to find some stock wheels and get rid of those 20's.
Ponyboychris
105
03-22-2011 07:57 PM
cdrmotorsports
12-25-2010 04:05 PM
FordF350Baby
01-06-2007 07:41 PM
