Hard steering when stopped or slow speed
I have a 2003 f250 with the 7.3 power stroke in it. It is factory height on a set of 285/75 16 tires. It already has a reman steering pump and I replaced the steering gearbox today due to the truck having a little slop in the wheel. Since I bought the truck it is dang near impossible to park in a parking lot and almost impossible at a stop sign or being stopped to get it to turn whether I'm on the brakes or not it doesn't seem to make a difference. What else could be affecting the steering on the truck? All the steering components are good. I'm about by to the point of just selling the truck because it's that hard to steer. Especially trying to back a trailer is hard too. Any help is greatly appreciated.
Seams to be a common problem and worse with the diesel , My 03 wont turn if I am on the brakes when stopped.
This is common and has happened on all of the diesel trucks I've owned. It might be because the low RPM of the engine makes it more difficult for the pump to turn at idle. Although I could be 100% wrong...
EDIT: Generally if you get the tires rolling a bit, it makes it a hell of a lot easier to steer. At least for me
My gas '04 did this. My mechanic buddy who worked at Ford for many many years seemed to think it was common and that it was the pump. He also said he could replace the pump and it would fix it, but that the new pump would have the same problem. Maybe in a week, maybe in 10 years.
I elected to leave it alone. Only very rarely did it cause a problem.
-J
-J
Originally Posted by weyland426
I have this issue and was recently told by my mechanic that there is a screen in the power steering fluid reservoir that gets clogged and reduces flow(at least for my 08). I plan to have it checked at my next oil change.
Yes. I'm about a month out on an oil change but will report back on whether this was an issue or not.
Playing_Tough
07-19-2006 04:51 PM
Pesky
09-12-2004 01:09 PM
