1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Power Locks
Old 06-04-2016, 04:14 AM
GoodandPLENTY's Avatar
GoodandPLENTY
GoodandPLENTY is offline
Power Locks
When I bought my truck the only way to lock and unlock the vehicle was with a key. I ordered up two door lock actuators from Amazon to fix half of the problem. When I started on the passenger side I noticed that the light didn't come on with the passenger front door open. After removing all the stuff to get to the lock actuator I noticed that I had a wire connector dangling. Upon further investigation the plastic connection separated from the metal door latch mechanism. Thankfully the door kept the spare parts that fell inside the door (spring and a metal V clip). Going for broke on a Friday night I guessed how the connector should go together and by the grace of God it worked. Well to make sure the connect didn't fall apart in the next few days I managed to get a zip tie to hold it together.
Zip tied the broken electrical connector and now it works.
Old 06-04-2016, 05:56 AM
Tom's Avatar
Tom
Tom is online now
Very interesting. Hope the zip tie holds up, otherwise you'll have to replace the sensor.
Amazon.com: Motorcraft SW5534 Door Jamb Relay: Automotive Amazon.com: Motorcraft SW5534 Door Jamb Relay: Automotive
Old 06-04-2016, 03:10 PM
GoodandPLENTY
Thanks Tom!!!
When I go back into the door I will replace both items 1) Door Jamb Relay and 2) Door Latch Assembly.
Question: How are you able to find the part number on Amazon? Obviously you have provided me one of them by posting the "Door Jamb Relay" but when I try to look up the latch assembly it's a no-go at this station....
Old 06-04-2016, 03:21 PM
Tom's Avatar
Tom
Tom is online now
I found that part on RockAuto. THe SW-number is a retail part number, so Amazon typically carries them. I looked it up and posted the link.
You can also go to parts.autonationfordwhitebearlake.com and pull parts diagrams and grab the part numbers from there.
Old 06-04-2016, 10:55 PM
GoodandPLENTY
You can also go to AutoNation Ford White Bear Lake | Parts & Accessories and pull parts diagrams and grab the part numbers from there.
Dude that's awesome...thanks for the link!!!
Old 07-05-2016, 08:09 PM
GoodandPLENTY
Follow-up as I have a new switch (SW-5534) but I'm waiting on get a new door latch which is in transit before I install them both. I ordered up two more power locks and have one left to install on the back of the quad cab.
mike L
12-23-2012 10:35 AM
Adamjr
09-22-2009 06:25 PM
49willard
01-25-2008 09:08 PM
Downriver Thunder
07-17-2006 09:05 AM
hughie
Bronco II
06-24-2003 02:20 AM
Quick Reply: Power Locks
