Tire Pressure on the OEM Michelin's
Believe it or not, they've thought about all that already. I used to think it was required to bump the pressure up to the maximum sidewall numbers when towing or carrying heavy loads. See what your owner/operator manual has to say, tire manual, do the math etc. You might be surprised. It's very difficult to break old habits.
My opinion is that you want the tire to touch flat across the tread. But the pressure required to do that differs based on load, with more pressure needed for more load.
I have a concrete driveway that isn't used much and the concrete chalks. Drive over it and the tires pick up the chalk, showing how much of the tread is touching. That's the way I fine tune pressures - within the range given in the manual and less than the max on the tire.
Tire pressure is a factor in the load capacity of your tire. The load your tire can support is based upon being inflated to the max pressure on the sidewall. But often this capacity is much higher than the rest of the truck. The drawback of keeping your tire at max capacity is the ride quality isn't as good, there is less grip and the tire will wear unevenly. The tire pressure on the door sticker alleviates those problems. I can't seem to find an online calculator tonight, but past experience has shown me that the tire pressure on the door sticker drops the tire capacity to closer (but not under) your axle limits.
I didn't like the squishy feel of my 18" dia tires at 35 PSI, so I bumped it to 40 (42 actually according to the computer). My contact patch is still solid and the ride is better, so that's where I'm going to keep it. I suggest just finding a pressure that works best for you; but don't worry about your loads. You're still within the limits of the tire.
DoofusOfTheDay
10-22-2013 05:31 PM
8 burnin 2 turnin
19
06-02-2009 02:19 AM
