Joying HU updates, upgrades, ROMs, installing/Tips and tricks, ect
Ok Due to the other thread that we have for the digital gauges starting to get a bir crowded and possibly?? off topic a tiny bit I figured I would move the Joying HU discussion parts here, well at least split it off so were not excessivly filling the thread with things that are semi off topic...anyways have fun and lets discuss the Joying unit, every thing from installing it to ROMs and what ever else
If you are interested in reading the original thread about the gauges and related info click the link who wants all digital read out gauges exhaust and fuel pressure too (the original thread that started this discussion)
As far as display of gauges goes it will be the same as a tablet, just in your dash verses a separate mount and hardware/charging cable and USB adapter and can play with other things like radio or what ever else you want to have like nav...
I ran the factory rom on my Joying unit for a short time. I neither liked it or disliked it...I was more intrigued by the possibilities of a new and improved rom. As I stated, I run the May 22 rom by Malaysk on the RK3188 1024 x 600. Xposed modules activated. Currently have the speed/clock screen saver enabled...and need to sit down and either change it or disable it...preferred would be disabled.
We should link that old gauges thread to this one. There's a ton of information there. I'll get you the XDA links this weekend for how to update ROMs and whatnot.
My bluetoothed input sounded terrible, very tinny and hollow whereas the radio sounded fine equal to OEM.
I contacted Joying and they recommended I change the BT level in the factory settings menu. I have not done so yet but I will tonight and report back.
I can't say enough about the support from Joying. They have contacted me many times and always replied to my requests with in 12 hours.
I am still on the fence about the Malaysk ROM as I am not exactly sure what I want to change.
I am having trouble getting my OBD ELM 327 device to connect, it has always worked fine on my Samsung S3 but I have only got it to connect once to the truck. It connects to the head unit fine but won't connect to the truck.
What type of speakers are you using, some times speakers do play a roll in the "tinney" sounding noises, not saying your wrong or any thing but I also noticced the same with the Ford stocks that came in the truck and better quality sound with my "After Market" speakers I have in the truck now, haven't really done extensive testing but what I did I did notice a difference between stock/aftermarket and no I have NOT messed with any settings yet (want to get the radio permanently installed first before I configure it)
They are some Phoenix gold replacements from a wholesaler years ago. I have hated them even after replacing the OEM on the OEM radio however on the Joying FM radio they sounded better and the Bluetooth input sounded worse.
A amp and new speakers all around (quality this time) will solve the problem.
My levels were already at 9/14 so I bumped the bt level to 19 and its allot better. I think the amp in the head unit runs out of headroom when turned up too high so boosting the incoming signal helps keep it in the curve.
