Rear end roaring
Rear end roaring
After putting my front end back together except new springs, new shocks, and new track bar, just to give everyone a little history of what I've done to it. I've had it for 8 months and maybe put 1000 miles if that because of working out of town a lot and the front end torn apart. I've noticed a louder roar coming from the rear end when taking my foot off the accelerator without pressing the brake. It feels like the tow button is engaged, but isnt. I have no issues with handling besides knowing it still needs alignment. I'm taking it to the dealership tomorrow for a 4 wheel alignment. It sounds and feels like I'm riding on mud terrain tires. Any thoughts?
I'm fighting a similar noise right now, though, I wouldn't classify it as a roar. Starting at about 30mph I can hear a whine that seems to be coming from the rear end. It's there on accel, decel, cruising speed, etc...
Are you sure it was the pinion seal and not a worn pinion bearing that was tightened up a little during the seal replacement?
As mav points out,
the seal is likely not the real problem but a result of a bearing going bad.
Even the Timken seals on Rockauto aren't $20 - I think they're under $10 . I had one changed with a Timken on my F250 several years ago - paid $12 from Amazon. Be a cold day when I pay $75 from a dealer for a pinion seal.
When I had it align, a Ford tech said that it was leaking. That's his .02. I definitely have a pinion seal leak, that's a no brainer. But since I'm replacing the seal, I guess I should replace the bearing also and my brother suggested that I should replace the wheel bearings so I'm starting on a clean slate.
