Gauge repair
Gauge repair
I have a 55 F-350 with gauge issues. The ammeter doesn't work. Took the cluster out an cleaned and painted that and fount that there is something apparently missing from the rear of the meter. I am guessing it is some type of inductance pickup coil.
Can anyone verify this for me? If I am correct, is there a place I can purchase the missing piece(s)? Thank for helping out.
ALBUQ F-1 ,
There is nothing connected to the ammeter. There is a bracket there that looks like it should hold the inductance pickup coil.
I have no real idea what the difference is between the ammeter as shown in the chart you sent me. I think it may be a tool in finding out more info though. Thanks!
The 48-56 F-Series Parts Manual on CD, available here:
1948-56 Ford Truck Master Parts Catalog CD - HiPo Parts Garage
Cheap at half the price! It has both the Listings (like above) and exploded views of all systems.
Do a Google search on either of those parts numbers, several vendors have them for about $20. I'd guess the B6J number is most correct for a 55.
Hi, On my 50 Ford there is a big wire that comes from or goes to the ignition switch and passes through the loop on the back of the ampere meter and disappears into a wire harness.
When I went to 12V negative, I had to remove the wire from the ignition switch and pass it through the loop on the amp gauge in the opposite direction to get the gauge to read right.
So find the big wire that passes through the loop on the gauge and if the gauge reads backwards, reverse the direction of the wire. Hope this helps.
Be sure to unhook the battery before taking the wire loose.
just make sure to leave the insulation on the wire that passes through the loop and it only goes through one time. somebody on here not too long ago had stripped the wire and wrapped it through the loop several times to ensure good contact. Luckily he had the wire protected by a fuse or it would have been a good fire starter.
Dano78
03-28-2013 07:53 PM
woodsmoke
02-17-2012 12:39 PM
