Ignition Actuator removal for 1989 F250
Need some detailed help in removing the actuator mechanism that's tied into the cylinder lock/ignition system. When I pulled the cylinder key lock assembly there's a C Clip at the bottom. Does this have to be removed in order to pull the upper actuator out? I think the gear(s) may be stripped. When I turn the key to start sometimes nothing happens. If I hit the top of the steering wheel it starts. It'll also start if I push the ignition rod down, it always starts. That's why I think its the gears.
Clockwerk_rat
23
04-21-2017 01:08 PM
BombThreat
04-15-2015 05:25 PM
n.zastrow
11-27-2011 05:01 PM
89Bronco_EddieBauer
1978 - 1996 Big Bronco
01-03-2004 09:11 AM
