2000 Lightning Transmission Question
My transmission goes into neutral when I come to a traffic light or stop sign 90% of the time. I press the gas to go and goes into gear. I can put the shifter to neutral position and back to drive and it's fine. No other issues occur while driving, shifting is smooth. Any info would greatly be appreciated.
I agree with mark
Either the filter came loose or fwd drum issue .
Excessive clearance , cracked apply piston or possable input shaft ring wear or inner stator damage . Best bet is too pan and check filter . If it is down don't forget to remove the old orange metal clad seal for the filter . It will be up in the pump cover . Install new filter with seal on filter inlet . We use assembly lube but you can use ATF . Don't bang it up with hand . Work it up , little wiggle . We have seen do it your sellers crack the filter where the neck meets the body .
Good luck .
Let me know .
Ohh use Mercon 5 . I highly recommend motorcraft . Don't fall for the universal bs
Good luck .
Let me know .
