Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's
2000 Lightning Transmission Question
Old 05-24-2016, 06:38 PM
taterhunt's Avatar
taterhunt
taterhunt is offline
My transmission goes into neutral when I come to a traffic light or stop sign 90% of the time. I press the gas to go and goes into gear. I can put the shifter to neutral position and back to drive and it's fine. No other issues occur while driving, shifting is smooth. Any info would greatly be appreciated.
Old 05-24-2016, 08:18 PM
whomrig's Avatar
whomrig
whomrig is offline
did you check the fluid level? how many miles on your rig? has the trans been serviced?
Old 05-24-2016, 08:23 PM
taterhunt's Avatar
taterhunt
Fluid is fine. 191,000, not recetly
Old 08-30-2016, 08:02 PM
joeytotalauto's Avatar
joeytotalauto
joeytotalauto is offline
Does it have the large 4R100
Or the smaller 4477W
Easy to tell the larger trans has a massive rectangle shaped pan
And the smaller one is a square with 2 sides diagonal
Old 08-30-2016, 09:59 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Mark Kovalsky is online now
Received 1,576 Likes on 1,054 Posts
All Lightnings had the 4R100.
I think either your internal filter is loose, or the forward clutch is damaged.
Old 08-30-2016, 10:38 PM
joeytotalauto
I agree with mark
Either the filter came loose or fwd drum issue .
Excessive clearance , cracked apply piston or possable input shaft ring wear or inner stator damage . Best bet is too pan and check filter . If it is down don't forget to remove the old orange metal clad seal for the filter . It will be up in the pump cover . Install new filter with seal on filter inlet . We use assembly lube but you can use ATF . Don't bang it up with hand . Work it up , little wiggle . We have seen do it your sellers crack the filter where the neck meets the body .
Good luck .
Let me know .
Ohh use Mercon 5 . I highly recommend motorcraft . Don't fall for the universal bs
sweetfarm
06-30-2021 07:50 PM
BuschWacker
12-22-2018 04:32 PM
Steves2000
1999 to 2016 Super Duty
52
11-19-2013 08:29 PM
knight60626
11-24-2005 10:00 AM
EagleDakota
1997-2006 Expedition & Navigator
06-26-2005 01:22 AM
Quick Reply: 2000 Lightning Transmission Question
