Clean out gas tank?
I used the POR-15 kit but did most of what you mentioned below. I have an electric cement mixer and tack welded a scrap piece of flat bar to it, drilled a couple holes to match up to the gas tank mounting holes and fastened it to the mixer. added a gallon or so of gravel from the driveway, duct taped the holes and turned it on for about 4 hours. no rust after that! then rinsed with water several times and did the POR-15 kit. Worked great. Did this for my 50 and 52 tanks. Probably would've made sense to buy new tanks but it was fun.
Tanks are relatively inexpensive for our old trucks. However, if you want to tackle it yourself, it's pretty straight-forward. Here's my method:
1 - Rinse & flush with water to get larger particles out.
2 - Put about 1 gallon of denatured alcohol, along with a handful of roofing nails, nuts & bolts, or something else you can use to shake around - seal up the openings well with duct tape.
3 - Shake, rattle, & roll. Be sure to shake and slosh with all 6 sides at the 'bottom' of however you hold it. I've even heard of folks strapping it to a tractor tire and driving around the field for a while. You can't shake it enough. When you're tired. Shake it some more.
4 - Did I mention to shake it?
5 - Open it up and rattle all the junk out. Rinse with denatured alcohol until it's clean.
6 - Pour in about 1/2 gallon of muriatic acid. Be very careful with this step as it will burn you, etch concrete, and create fumes you don't really want to inhale - do it outside. Carefully slosh the acid around all 6 surfaces of the tank - be sure to get the top well. This step removes the rust.
7 - Rinse with water.
8 - Rinse with alcohol.
9 - Put about a 1/2 gallon of phosphoric acid in and slosh it around carefully. Same precautions as muriatic acid, but it's not nearly as caustic - still, you don't want it on your, concrete, or your clothes. When done and certain all 6 sides are coated, dump it out and let it dry overnight.
10 - The next day, rinse with water.
11 - Rinse with alcohol.
12 - Reinstall.
13 - Forget about your tank and move on to the next project....
12 - Reinstall.
ssj7kids
09-21-2008 08:06 PM
spinninspur
09-14-2003 09:16 PM
