Rough Idle issue
Rough Idle issue
I have a 76 F-150 460 CI with 57,000 miles on it.The carb was replaced everything else is original. It has been running very good but suddenly has a weak idle. It has plenty of power on acceleration and at cruise.This almost feels like the distributor is being moved retarded during idle, it has that low RPM shivery idle.
I have adjusted Idle mix and idle speed I can tell it is compensating A/F ratio and not correcting by how far out I have to turn the screws. Is there anything common on these engines I should look at beyond normal vacuum leak checks and fouled plugs?
I also pulled plugs out they are NGK plugs not sure I would be a fan of these plugs but they were all equally light brown ,fairly clean and even looked new on the outside shell. Plug wires do appear to be aftermarket and in good condition.
OK I checked those and they are torqued none were loose or uneven..no change in symptoms. Rechecked for vacuum leaks there, none present on intake top side at least.
I checked dist cap/rotor, secondary wires and vacuum advance movements. Centrifugal has movement when I turn the shaft..still could be a possibility. And I thought back ..this started within hours after I fueled the vehicle. I switched to front tank which was fuel from a different station..still did it anyway..was thinking water in rear tank.but that idea was eliminated..Now this has an edelbrock 750. I cannot find an external fuel filter inline..Does the 750 have one at the fuel line inlet?
I was on the same thought because this comes and goes from throttle changes when it happens..I might need to check that with a light..I do get a noticeable surge at light throttle anywhere from 25-45 MPH This is where I have discovered the Dist is frozen to the block..not going to chance breaking a housing.
Well I took the carb off and found scum and debris in the float bowl, cleaned all passage ways out and it runs good. presently It has however suddenly changed idle speed it has gone from 1,000 down to 600 just like a flip of a switch. some times it jumps back up to 1,000 I am thinking may have centrifugal weight issues/distributor problems as well.
Problem completely solved: Carb was dirty and some passages were plugged, I had found manifold vacuum port on the carb was partially plugged and was improperly working making the vacuum advance on full advance sporadically this making idle speed and quality vary. Once I switched the vac adv to ported vacuum like it should have been.. it ran perfect, rebuilt carb just for reassurance.
handsomerob
16
09-24-2007 06:05 PM
