Help.... chugging etc.
Old 05-18-2016, 02:24 PM
crowncrazy87's Avatar
crowncrazy87
crowncrazy87 is offline
Ok. 1998 F150 xlt with the 4.6L.
So I was getting a lot of engine stutter/misfire. Pulled codes it said misfire on cylinder 7.
Replaced wire and plug, no change.
Replaced coil pack, no change.
Replaced injector, still chugging under medium acceleration but no misfire code now.
No other codes or pending codes are showing up on my reader.
I did record some live data but have no clue how to interpret the numbers.
Old 05-19-2016, 07:52 AM
steve(ill)'s Avatar
steve(ill)
steve(ill) is offline
I have had the same problem with a 2006 with 4.6 motor.. changed coil 2-3 times. fixes it for a couple weeks...... recently I have narrowed it down to the coil wire that has a harsh BEND around the PCV valve hose........ seems that when I bend it one way or the other, it will fire or miss........... just something to consider --- bad wires.
Old 05-20-2016, 08:08 AM
crowncrazy87
I'm starting to think the same thing. I got to get it fixed before the 27th as we have a big camping trip planned and need my truck to haul all our gear to the mountains.
I will keep posted about what I get figured out.
TheGageinator
2004 - 2008 F150
03-07-2014 12:14 PM
southernraceman
2004 - 2008 F150
02-08-2011 07:44 AM
broken ford truck
1997 - 2003 F150
07-01-2010 09:19 PM
oldsub86
1997 - 2003 F150
08-24-2008 08:35 AM
sandzilla
1999 to 2016 Super Duty
09-27-2006 12:00 AM
Quick Reply: Help.... chugging etc.
