p0171 and 174
p0171 and 174
So I have a 1997 ford f150 v8 4.6 2w
I got codes p0171 and 174 my truck seems fine till the idle drops it's weird when I have it on park it's fine if I turn the wheel left the idle drops when the ac turns on the idle drops and it's wasting crazy gas
Where should I start first in finding this problem?
A look at the code descriptions will tell you the motor is running lean.
A lean condition is to much air.
The Computer has shifted the fuel tables rich to account for the fault.
This why the idle and gas consumption is out of wack.
Find the air leak into the intake tract.
Look at the PCV hose rubber fitting in the rear of the vertical intake manifold as a start.
Good luck.
Good luck.
This code pair is almost always caused by either an intake vacuum leak, contaminated or defective MAF sensor, or a weak fuel delivery system that is not delivering adequate fuel volume at pressure. 90+% of the time, it's an air leak and it's almost always the PCV system at fault. Once in a while, it will be a cracked intake manifold or gasket or, on some engines, the isolator bolts.
Spray some carb cleaner around the upper intake manifold and the hoses there. If the idle stumbles you have narrowed the area down to where you are spraying.
Ya man the brakes feel spongy and loose
RickS1986
09-28-2014 04:16 PM
betard_foosier
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
03-19-2014 05:25 PM
