Weird Tow haul Problem
Did some searching but cant seam to find anything similar to my problem,
Truck is a 06 F350 4x4 with the 6.0 and a 5r100w trans,
All has been great, tow quite a lot with it, not huge load 6000 or under most of the time, truck is all stock, except a exhaust and cold air intake, SCT programmer on the 65 horse tow setting,
Ran this set up for over a year and like it know problems, then one day I was coming down a hill, NO trailer on, hit the tow haul button as I always do on this hill so I don't drag my brakes and the light started flashing, Got the P0751, SSPCA solenoid stuck off, I tested solenoid and was at the bottom edge of the specs so I throw another one in there to be safe, also the fluid in pan was spotless, I drain the pan every other oil change, this thing is clean, Went on a test drive and same problem, the trans shifts perfect in all gears forward and revers, perfect every time, until I hit the tow haul button,
the other weird thing is I don't have my compression breaking until after the light starts flashing, also weird,
If I manually pull it out of OD into 3rd, Light starts flashing, even on level ground, also noticed it doesn't drop down a gear when I hit the button anymore, it would always drop down a bit and hold a gear longer, it wont do that any more, Inspected the harness and cant see anything, I did chand the VSS in the rear diff a few weeks earlier, because my ABS light came on, but just at a loss as what it could be, any tips or advice would be appreciated, thanks KH
A minor correction, it's a 5R110W trans.
My list shows that this code is SSA, not SSPCA. Those are two different solenoids. Which one did you replace?
Did you test it by applying 12 volts across the two pins to see if the solenoid actuated or is stuck? Just testing resistance won't tell you anything in this case, the code isn't for an open circuit, it is for the armature in the solenoid being stuck.
[/QUOTE]
[/QUOTE]
Well today something new happened. Was getting on the onramp and not sure what gear but seems like it was 3rd to 4th when it just free spun like it was in neutral. Let off and it stade in free spin for a few seconds. Then shifted in gear. Tow haul light started to flash and same code came up P0751. Thanks KH
Well whatever was wrong finally went all wrong, going up a hill trans went into free spin and have no forward or revers, Only code that came up this time is a P0730, Incorrect gear ratio, Got it home and on the hoist and the pressure test is way out of spec when in any gear, Revers bounces back and forth from 0 to 400, then settles out at 400, the others are 377 or higher and have a lot of pulsation in them, going to do some more checking tonight, Might try and shoot a Vid of the pressure gage tonight also, Thanks KH
Tow haul
Mine has had a similar issue. I have a 2006 350 SRW 6.0 and tow haul would flash when first leaving in the mornings, turn engine off and back on and it would go off. Codes were P1780, P0751, and P2700. Ran fine, then a couple of weeks later while going appx 45 mph truck acted like in neutral. Coasted to a stop and would not go in any gear, would only act as if neutral. Had towed into ford shop and now they say new transmission. They haven't tore into it yet, and I keep hoping it's something else.
Found it
Well Got the trans apart and found the problem, Hub was broken it 2 pieces, Honestly if I wouldn't of messed up my pump hub taking it apart, I would just replace the hub and clutches on that component and put it back together, but I chipped the hub by accident, but I really wanted to verified the problem before sticking a new trans in, would hate to brake another one, Everything els looks good and measures out, Thanks For the Help guys,
Yes it was, As soon as it cracked was why I got the first code P0751, it would not let it build pressure for the coast clutch, then of course it was only a matter of time before it failed 100% the second code is what gets set for the incorrect gear ratio after it slits apart, I guess its a very common problem, most weld them up. also the pins on some of the planetary gears also, I have to say it honestly is not that bad to pull down, If I had access to a few tools like the seal instillers and a couple other specialty tools I would tackle it myself, Thanks KH
