Push Horn pad (with cruise) blow fuse....
The reason I asked, the horn wiring is different on a truck with cruise.
On a truck with cruise, the horn wire is grounded by the steering wheel and uses a relay. Without cruise the steering wheel switches the positive wire of the horn.
If you had the + non-cruise wire going to the horn and put it on the cruise system it would blow the fuse everytime, since the cruise system grounds the wire.
I think you are on to something. pulling the horn/cruise pad off the wheel, there are 3 wires,
Black
Blue
Yellow with blue dots.
The black has a post on it and goes into a hole in the column, (ground)
the blue and yellow with blue dots ate in a connector and plugs into the two male spades on the column.
Now jumping the two n the connector, the horn blows, (with the Black unplugged)
black plugged in and blows the fuse.
SO the wiring in the column looks like a non-cruise harness, according to EVTM, Yet the thing has cruise amplifier and horn relay......
Black
Blue
86f150step
09-23-2013 07:21 PM
Reefmonster
1997-2006 Expedition & Navigator
01-03-2012 07:49 PM
1988midnightblue
06-22-2007 07:24 AM
harley7
12-28-2004 07:13 PM
