Rebuilt the ZF 5-speed this evening. Wicked wheel, and TS 6-position chip came in today as well.
The little gear on the edge of the case is out of my old Mustang. It's a G-Force T5 3rd gear. Made me laugh like hell how big the ZF 5-speed gears are.
Donor truck is pretty much stripped of the parts necessary for the swap. Pulling the blue truck into the garage tomorrow to start getting the front end apart over the next few days.
Got the dash out today, swapped dash harnesses, swapped the pedals. Truck has the correct amount of pedals now. Lol. Also mounted the gauges. Got a pyrometer, and boost gauge. Swapped the transmission tunnel plate for the manual while I was in there.
Well, the engine, transmission, shifter, front driveshaft, rear fuel tank, and fuel lines are all in the truck. Chassis harness had to be extended too, since it came out of an extended cab truck.
Also, the forward half of the rear driveshaft needs to be extend 6.25", since the 5-speed is shorter than the automatic. Transmission mount is in a different location too, so I had to use the trans crossmember out of the green truck. Fortunately, the frame was already drilled for it.
