Project tow pig.
Old 05-08-2016, 09:44 AM
90geetee's Avatar
90geetee
90geetee is offline
Project tow pig.
I currently have a 94 crew cab long bed 4x4 F350. It has a 460/E4OD in it right now. This is the truck.
Picked up a donor 96 F250 4x4 with a 7.3 Powerstroke, and a ZF-5 speed. This is the donor truck.
So I imagine you can figure out what's happening here. Lol. Got the engine and transmission out of the donor truck yesterday.
I'll keep you guys updated with the progress on this!
Old 05-11-2016, 11:44 PM
90geetee's Avatar
90geetee
90geetee is offline
Rebuilt the ZF 5-speed this evening. Wicked wheel, and TS 6-position chip came in today as well.
The little gear on the edge of the case is out of my old Mustang. It's a G-Force T5 3rd gear. Made me laugh like hell how big the ZF 5-speed gears are.
Old 05-12-2016, 12:52 AM
bmxerbrett's Avatar
bmxerbrett
bmxerbrett is offline
Pictures remind me of my old neighborhood near Tucson Arizona.
Old 05-12-2016, 05:33 AM
CTC01's Avatar
CTC01
CTC01 is offline
WOW!!
Your "donor" has better sheet metal than my "good" truck.
CURSE YOU SNOW, ICE AND SALT!!!!
Cool project, I'll keep watching.
Todd
Old 05-12-2016, 05:30 PM
90geetee's Avatar
90geetee
90geetee is offline
I'm in Marana, AZ. Lol.
Old 05-12-2016, 05:32 PM
90geetee's Avatar
90geetee
90geetee is offline
Originally Posted by CTC01
WOW!!
Todd
Thanks man! It's a big project, but I'm really excited about it! Still have a ton of work ahead of me though. Lol.
Old 05-12-2016, 09:39 PM
bmxerbrett's Avatar
bmxerbrett
Nice! I lived in Rancho Sahuarita.
Old 05-12-2016, 10:04 PM
90geetee's Avatar
90geetee
90geetee is offline
Lol, nice! Waaayyyyy down south from me. About an hour.
Old 05-12-2016, 10:38 PM
90geetee's Avatar
90geetee
90geetee is offline
Installed the Wicked Wheel in the turbo today after work. Also bolted the transfer case back up to the transmission.
Old 05-17-2016, 11:40 PM
90geetee's Avatar
90geetee
90geetee is offline
Donor truck is pretty much stripped of the parts necessary for the swap. Pulling the blue truck into the garage tomorrow to start getting the front end apart over the next few days.
Old 05-19-2016, 12:16 AM
90geetee's Avatar
90geetee
90geetee is offline
Tore the nose off the blue truck today.
Old 05-20-2016, 01:42 AM
90geetee's Avatar
90geetee
90geetee is offline
Got the dash out today, swapped dash harnesses, swapped the pedals. Truck has the correct amount of pedals now. Lol. Also mounted the gauges. Got a pyrometer, and boost gauge. Swapped the transmission tunnel plate for the manual while I was in there.
Old 05-21-2016, 06:11 PM
90geetee's Avatar
90geetee
90geetee is offline
It's going in! That's literally right now.
Old 05-22-2016, 01:15 AM
90geetee's Avatar
90geetee
90geetee is offline
Well, the engine, transmission, shifter, front driveshaft, rear fuel tank, and fuel lines are all in the truck. Chassis harness had to be extended too, since it came out of an extended cab truck.
Also, the forward half of the rear driveshaft needs to be extend 6.25", since the 5-speed is shorter than the automatic. Transmission mount is in a different location too, so I had to use the trans crossmember out of the green truck. Fortunately, the frame was already drilled for it.
Old 05-22-2016, 09:19 AM
GoinBoarding's Avatar
GoinBoarding
GoinBoarding is offline
Good progress! Figured someone ought to offer up a little encouragement.
Quick Reply: Project tow pig.
