I ordered mine from bus depot and it required a short stem. I think I ordered a 192° from international. This is the picture of a long stem sitting in the pump that requires a short stem.
the 203 is way to effing hot, need to get like a 190 in there or something.
anyone have part numbers i can send to clay??
Why is 203* too hot? It's my understanding that the 7.3 is more efficient at 203* then a lower temp and the higher the T-stat temp the longer
the radiator has to cool the coolant.
The 203 stats dont keep you at 203.
I'm running unloaded at 220 temps.
No bueno!
I've been running the 203 stat for awhile now. I only have the stock Ford dashboard gauge but it shows about the middle. I'm going to hook up a real gauge and see what temps it's running at. My injectors and turbo are stock so far and I don't have a chip. I don't do much heavy towing, just a camp trailer and an occasional heavy load on a flatbed but not very often.
