No power good battery
If you put a test light or VOM across the battery does it register?
Does the horn work?
If you jump across the starter solenoid (+ terminal to small wire) does it crank?
It sounds like no power is getting to the ignition switch.
What year truck? We need to know that to get further into the root cause(s).
Does the horn work?
Edgethis
16
02-03-2011 06:40 PM
FordGuy91
11-17-2010 04:42 PM
Mounty 98
08-08-2008 08:06 PM
