Injector swap
Injector swap
So I own a 1997 7.3 and I'm looking to replace my stock single shot injectors for a set of injectors I found on Craigslist from a 1999 superduty. I was wondering if this is possible to just buy his injectors and do the swap no problems? My truck does have a ts 6 position chip so my truck is tuned to handle the extra gas.
If they are dirt cheap and are actually in good shape (you will have absolutely no way to tell, so don't pay a lot for them) then you can put new O-rings on them and drop them in and the truck will run just fine. Lots of guys with older trucks have done it since newer injectors are generally much more plentiful and have better parts in them so they are generally in better shape than worn out OBS injectors.
If they are from E'99 and are AB codes, PASS on them as fast as you can.
If they are '99.5 AD codes then there's at least a slight chance they are any good.
If you want to install them with the hopes of more power/performance, then there are better ways to go.
__________________
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
You don't HAVE to upgrade anything to run the Split Shots, but you will if you want to optimize what they are capable of.
Like I said you can re-o-ring them and drop them in and they will work for you just fine (as long as they are in good shape.)
$100 for a set of 8, we buy them all the time, I have piles of them.
__________________
My truck only has 150k miles so it's barely even broken in yet.
