Engine power increase?
There's much more of a loss than just parasitic drag. These engines are 'torque managed' to keep from blowing the drivelines up. You rarely get anything close the figures quoted. All the manufacturers do this, and I think it's total B.S..
While this is true, it doesn't paint a complete picture. Having a nanny on a 800 ft/lb motor is < having a nanny on a 1000 ft/lb motor. So, while we may not be getting the full load at all times we are getting more than the last two generations of the 6.7 and that's what folks are excited about.
Why bother to engineer a massively powerful diesel engine if the transmission cannot handle it? Wouldn't it seem smart to upgrade the transmission to match?
The current 6.7L diesel supposedly puts down 860lb-ft @ 1600RPM. Why is it so hard to turn the tires by flooring the truck, then, even with traction control off? There is hardly any weight over those rear tires. Yet with our F-150, either the current 2.7L or the old 5.0L, you can effortlessly light up the rears with traction off! I would think 860lb-ft would utterly shred the tires!
Instead, you "feel" the torque surge in higher gears when already moving.
Whatever. Even though I had many reservations and second thoughts, I'm switching back to the gas truck...although even that is power-limited until a certain RPM is reached.
I have a buddy who drives a 2009 Duramax. That Allison must be one tough tranny because his truck is running a DPF and EGR delete, larger turbo, straight pipe 6" diameter, injector upgrade, and a performance tuner. He drives it hard; he lights up his rear tires almost every time he takes off, and that truck just sounds evil. The trans has not been modified and it seems to be holding up fine.
I'm not advocating driving like that, but once in awhile...
I'm curious how many miles a year you put on a truck troverman. The list in your signature shows 4 trucks over a 6 year span? What's the story there?
I outgrew my "burn the tires" phase many years ago. Dudes who do all that to their truck and burn up high dollar tires are compensating for insecurities.
The trucks usually have about 25k when I trade. The truck I have ordered will be the last for at least 5 years. Money will not be as free flowing next year. I have been fortunate to have the other trucks.
I peel out once in awhile, just because I feel like it. But not often.
02GrayPowerStroke
02-18-2010 03:37 PM
Red Star
Ford vs The Competition
13
07-20-2008 11:02 AM
builtfordtough13
34
01-11-2008 02:39 PM
