E4od delayed engagement in reverse. Defults to 2nd gear in all forward ranges
I once had very weak reverse after adding a shift kit in my trans, I found out it was the result of not tightening the valve body well enough. In your case is sounds like an electric signal problem, so I would retrieve codes to see what's the transmission receiving, it could be a sensor problem. But before anything more profound, unplug the transmission and clean the solenoid pack connector very well (it's the only connector going to the trans), then plug it and drive the truck, see if the condition went away. Maybe it's something as simple as having that plug loose.
BTW, welcome to FTE! I hope you enjoy it here and find what you're looking Ford (saw what I did there? ).
Usually the only 3 sensors that could be affecting the trans are the Manual Lever Position Sensor (MLPS, located to the side of the transmission), Vehicle Speed Sensor (VSS, located above the rear differential), Throttle Position Sensor (TPS, located to the side of the throttle body). Apart from that, the instrument cluster (PSOM) can affect the function of the transmission. Check those I mentioned and the solenoid pack plug, then I would look at the wiring itself, and finally the ECU.
Redneckfordf2502002
02-06-2012 05:18 PM
fordfan66
01-05-2007 07:35 AM
bradleygt302
03-08-2004 06:29 PM
