Upgrade a 07 Expy EL to trailer tow
Hi,
I have a new to me 07 expy el that I need to upgrade for towing. I understand that I need to add a trans cooler and a HD radiator, as well as wiring for the trailer brake. Are there any other points I need to cover and if anyone has sources for the components they would like to share, I'd be grateful.
Thank You!
Thank You!
Thanks, does not have the 7 pin connector, has 4 pin + capped trailer brake controller wire @ the hitch. I also have the under dash connector.
I looked on the forum for more on this and found that I've got 90% of what I need, have a wiring diagram for the truck on order, and will ID the wires on the 4 pin and add as needed for battery charging and other lamps (possible the backup lamp). One good thing is that I can put a 2016 F-250 plug @ the hitch, which is an upgrade from the original.
Will also add the HD radiator. and then expect to be good to go.
AK 440
1999 to 2016 Super Duty
08-22-2010 02:38 PM
paradiddle
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
11-05-2003 05:55 PM
