ignition switch fixed but wont start
First welcome to the forum.
When you say "burnt out" like how and was it just the switch or did it also heat up the plug so it is not making contact with the switch?
What caused the switch to burn out as I have not heard or seen that?
Does everything else work? Lights & what not when you turn the key on?
I would say start at the switch and see if you get power there when you turn the key and work to the solenoid. to see where the volts are leaving the wire.
Dave ----
Dave ----
These modules were so unreliable that Ford techs referred to DuraSpark as NEVER/Spark!
Yeah, I know about your NeverStart name for them, Bill... but we here generally like the DS2 ignition, and I suspect you guys gave it that name at the dealerships because all the ones with problems were in your face... but if you compare the number of the things made against the number that fail, it's really not that bad IMO.
Regardless, the ignition module has nothing to do with the starter motor turning over the engine or not, the two systems aren't connected.
He might get more help if he wrote more clearly & descriptive, paid more attention to his writing & grammar and wasn't so offensive....
Kwill
04-25-2016 07:40 AM
