A/C compressor doesn't start 1 yr after retrofit to R134a
Last year my 1993 5.0 V8's AC would momentarily start then shut off. I had the remaining Freon drained, put a vacuum of 30 inches on it and then did an R-12 to R-134a retrofit on the system. A/C ran great afterwards. Turned on the A/C this spring and the compressor no longer turns on. I'm wondering if the the compressor died because of the R-134a lubricant 'mixing' with any left over R-12 lubricant in the compressor?
Received 3,186 Likes
on
when you did the conversion did you flush the system, or just put the "ac killer" kit on?
you said yo you refilled the system to just under 45 psi. are you using the cheapo one side gauge, or a manifold set? to properly charge an AC system, you really need a manifold set to see what the pressures are on both the high and low side.
on
current status of non-woking A/C
After finding no voltage at the compressor, I verified the low side was above 30 psi and disconnected the plug to the sensor on the accumulator. Using an ohm meter I checked the resistance across the terminals on the sensor (not the plug) and found it 'open'. This would appear to mean the sensor is no longer working as I would have expected to read zero resistance if the sensor detected the 30 psi pressure. I apparently need to replace the sensor on the accumulator but am wondering if I have to drain the entire system of coolant before removing and replacing the sensor?
