Axle identification
Axle identification
On my 04 lariat 4x4 the axle code is 26, which from my research says 3.73 non limited slip. Which a 4x4 with non LS is a sad thing. But when I spin the tires they both spin. As if it IS limited slip. So maybe the chart I found was wrong? If I'm right an open axle should only do one-wheel-peels correct?
With both rear wheels off the ground, trans in Neutral and parking brake off, turn one wheel. The other wheel will turn in the opposite direction. With limited-slip, they both will turn in the same direction. Of course, a quick test is to simply spin the wheel on some gravel where you can see the evidence of spinning - one wheel will spin. With limited slip, both wheels will spin and it is usually harder to spin them than it is the one.
RustyWallace
09-08-2004 08:00 PM
