Dp tuner and wastegate actuator tube??
on
I don't think you will have to worry about the plenums. However, the boots and boot clamps may be the weak point if they are original...It will scare the heck out of you the first time you blow one.
Did Jody leave the commands to defuel at "x" PSI in the tunes, or did he remove them?
If he left them then you will not likely see above 24 PSI unless you install a boost fooler...you'll then have to install a separate boost gauge...you will not be able to rely on the PCM. If he removed them then you could see more boost than that.
Are injectors and turbo stock?
I don't think you will have to worry about the plenums. However, the boots and boot clamps may be the weak point in they are original...It will scare the heck out of you the first time you blow one.
Awesome thanks! Putting in s and b intake later. This truck really grew a set instantly! Can't believe what a difference the tuner makes, love it
Received 3,118 Likes
on
on
on
