56 f 100 turning over slow
I bough another 56 with original engine and running gear. No body work has even been done so i,m planning on fixing the rust and leaving it like it is as a driver. Replaced starter, solenoid and cables. The engine turns very slow when trying to crank. Any thoughts on what to check or replace next would be appreciated. Thanks HaroldMac
I will check the grounds tomorrow. As far as engine run no. The guy i bought it from said he had it running in 2009. The gas tank was taken out and he said as long as you pour gas in cab it would run. It does sound like maybe a ground issue. The starter was rebuilt last week and put a new solenoid on it with all new cables. Thanks for the info guys, I hope to come back with good news this weekend. Thanks again.
Grounds are so important. I was using a 12v battery on my 6v starter for a while with old cables. When I went back to the 6v it barely spun. New cables helped but it still struggled. These guys had told me about grounds but I'm pretty dense. Finally I ground the paint off the frame at the battery and starter ground. Wow! big difference. You only have to hit me in the head 4 or 5 times before I start listening to those smarter than me.
That isn't the first time I didn't read advice clearly or just didn't listen.
Hopefully it is just your grounds as well. That is such an easy fix.
Rich1953ard
04-28-2013 10:34 AM
Daves94vert
01-06-2010 09:19 AM
51PanelMan
29
10-20-2005 09:42 PM
jeffh
22
09-07-2005 11:02 PM
